Displays information about the MAC address lock down timeout feature for the specified port or group of ports or for all ports on the switch.
| all | Specifies all ports |
| port_list | Specifies one or more ports or slots and ports. |
N/A.
Port—Indicates the port number that you specified in the command.
MAC Lockdown Timeout—Specifies the enabled/disabled state of the MAC address lock down timeout feature.
Timeout (in seconds)—Specifies the timeout value for the specified ports. By default, the timeout value is 15 seconds. Even if MAC address lock down is disabled, the default timeout value is displayed.
The following command displays information about the MAC address lock down timeout settings for ports 2:3, 2:4, and 2:6:
show mac-lockdown-timeout ports 2:3, 2:4, 2:6
The following is sample output from this command:
Ports MAC Lockdown Timeout Timeout (in seconds) ====================================================== 2:3 Enabled300 2:4 Enabled 300 2:6Disabled 15
This command was first available in ExtremeXOS 11.6.
